Finnster
KillaHurtz
Finnster's Avatar
06.09.2009, 10:34 AM
Ahh, I think I'm getting it.
So when you shrink it down, width wise, you'll cut the sidewalls, but leave the bottom portion on.
Then you'll glue the half with the bottom portion sticking out, with the sidewalls cut short, under, or on top of the other half of the bottom portion.
Use ABS (How about PVC?) Cement, my dad has a few bottles laying around IIRC, and glue that together.
Sounds like it'd be pretty stiff.
So one half, of the box, will be higher than the other half, right?
Then you'll wanna sand it down, so it doesn't look all retarded, and voila, a box?
Hmm, very interesting...
LMK if I'm off track.
If you are talking about the top, then yes, once the halves are back together, one side will be higher than the other on the top. However, the boxes are quite tall, so you will chop the box down once its together so it will all even out. Lemme see if I can get some better pix.
