Frozen72
06.09.2009, 08:37 PM
OK it looks like I'm going to get one!!!
Topsy Kretts
Topsy Kretts's Avatar
06.13.2009, 12:34 PM
Hi all new here, I've been racing this little rocket now for over a month now,and if your on the fence about buying one? Buy 2!!! I have driven everything under the sun it seem's like,nitro and electric and this little pocket rocket has put more smile's on my face than any other car or truck in agesDon't let it's small size fool you,this thing is setting times at our track that made even the hard core nitro guy's take a second lookI have beat the snot out of this puppy,and still nothing has broke!Just keep an eye on screws loosening up.After several different set-ups this is the one I setteled on...Diffs 353 front to rear,40wt front shocks,35wt rear,no droop front or back,I also took off the shock boots,as they seemed to be limiting the travel.CC Sidewinder/5700 combo with the stock 14t pinion,a simple clip-on 8 fin heat sink on the motor,I also cut a hole in the middle of the front window to get some air flow.Without the hole I had some thermaling issue's,but none after the hole was cut.Ive been useing bowtie's or jconcept all around depending on how dry the track is.I put the truck on my scale's to get the balance with different batteries installed,and ended up using my 8000mah 20c Spec Point Concepts battery.The heavy battery made the balance all most perfect,and the extra weight kept the truck planted on the track!!!
