Finnster
KillaHurtz
Finnster's Avatar
06.10.2009, 09:54 AM
You are keeping the same total energy in batts, so you cannot expect a big % gain in runtime on such a swap (considering the 1Y is quite eff in the first place.)
To increase runtime, you will have to increase batt size (and weight.) The energy has to come from somewhere. You may get a min or so at most, but can be easily negated by driving style or pile up of mud/dirt on the car.
jzemaxx
06.10.2009, 11:14 AM
I figured the gain would come in the form of alot less amp draw.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
06.10.2009, 11:54 AM
If you double the voltage and retain the same overall vehicle and motor speed the amp draw will half. But seeing that you have not changed your overall battery capacity, just reconfigured it, you will not notice much benefit. You may pick up a little runtime, and the motor may run a bit cooler seeing you have halved the current passing thru it. Plus you will stress the esc less, and you could go to smaller wires to save some weight (not really worth it IMO.).
