zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.10.2009, 10:52 AM
23 minutes? That's it? That seems awfully low for the battery specs.
You need more voltage for that motor, running 4 or 5s I'm pretty sure would be more efficient than swapping motors and running 6s...
These Neu motors I think need more, and like a little extra voltage... imo, from personal experience. ~24,000rpm what you are running now is just not ideal at all for that motor, you should be up in the 32,000+rpm range, I'm pretty sure 40,000rpm is the sweet spot for Neu's.
