MetalMan
MetalMan's Avatar
06.12.2009, 02:03 PM
Got my motor today! It's nice having Neu about a 1.5 hour drive away.
There isn't really even a single scratch. The shaft has 2 flat spots, but that's the only thing wrong that I can tell. Also, the rear endbell is held on by 4 screws, and the front is held on by 1.
06.12.2009, 04:36 PM
Is having 2 flat spots a problem? Why?
bustitup
06.12.2009, 04:40 PM
lol ya he aint going to break that 8mm shaft with 4 flat spots on it
06.12.2009, 04:47 PM
I have a 8mm shaft 1527 that was in a jet edf and crashed at 150mph... Still runs true and does not have any issues. I doubt that you could ever damage that shaft easily...
06.12.2009, 04:50 PM
I did break the shaft on my medusa, but that's only 5mm.
MetalMan
MetalMan's Avatar
06.12.2009, 05:04 PM
One flat spot looks a lot cleaner than 2 Though there's nothing wrong with it per se.
Instead of having the shaft turned down to 5mm (maybe I like it thick ) I'm gonna try to set up my XLB with a 9mm wide plastic spur gear, along with a pinion of matching width.
06.12.2009, 05:25 PM
Pinion is gonna cover the other spot.
