Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Kcaz25
Kcaz25's Avatar
06.14.2009, 02:21 PM
Will 4 UE SuperShocks in any configuration hold up this ~11.5 pound truck?
If so what setup would one suggest? I'm a heavy basher with lots of +5ft tall jumps.
Any input would be very much appreciated!
And Neil I just ordered the Pico switch! Along with A TRX MMM mount, A spare Proline Steering set(saw it on the bay and couldn't pass it up), Robinson Racing Plastic Spur Gear 72T (spare)
Associated Factory Team Locking Adhesive
Bondhus 7-Piece Balldriver Hex Set Metric (bout time I got some proper tools!)
Associated Silicone Shock Oil 60 Weight (40 is way to fluid)
Futaba Servo Extension 3" J (Needed a short one to quickly and easily disconnect and reconnect the body lights to the reciever when taking the body off and on and this was the shortest one),
Traxxas Input Shaft Drive Gear E-Maxx
RC-Monster Sticker Sheet
Gorilla Maxx single speed transmission conversion (most important part! I figured no telling how long it's going to take Mike to make the CD/motor mounts If at all. And I wanted to drive my Maxx now so...)
Traxxas Gearbox Halves Front & Rear E-Maxx (stripped a screw hole in the motor side half of the tranny, the one side that the the Single Speed conversion leaves on and I figured that I need all the strength I can get if there are only 4 ~tightly spaced screws holding the heaviest single part onto the chassis that being the motor through the tranny)
Traxxas Output Gear 31T E-Maxx(again)
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.14.2009, 02:30 PM
Front 1/8 scale buggy shocks are the ticket ! They cheaper than UE and will hold more oil by volume and have 3.5mm shafts. They are easily scored for about 15.00 a pair on FleaBay. regardless what brand you buy the spring rate my be a little light for bashing but firmer springs are obtainable on FleaBay as well.
OBTW, Nice Truck !
