Ryu James
Ryu James's Avatar
06.17.2009, 03:59 PM
the one you have pictured is their version1 2 shoe clutch and was ok but i didnt like it as much as using a pinion.
their new 3 shoe electri clutch is pretty awesome though. i run it in all my buggies and truggies now. i just switched over from direct drive like a month ago and i definitely prefer the clutch now.
i run the softest springs (.7mm) for quick engagement and i run both soft and hard shoes depending on need.
the clutch is awesome for better control. i do much better on the track when accelerating and in the corners. also you have much more turn in when free rolling. less abuse on the motor since its not connected to drive line. and also you get the benefit of using mech. brakes. i love mech brakes. have to have 'em imo.
temps on your motor will be slightly higher due to the motor spinning a bit more before engaging so you might want to go up 1 tooth in your clutchbell over what you ran on your pinion.
these clutches are very low maintenence too. i have been running mine for a month now in extreme race condition and neither my soft or hard shoes are even close to worn out, my bearings are fine too. the temps dont get near as high as a nitro clutch so there is not as much abuse to the clutch setup.
anyway, making the switch is an adjustment at first but you will notice for racing that you will have much more control. even if you are good already and use exponential setting on your transmitter etc. its not the same as a clutch.
anyway, thats my opinion on the matter. you will definitely get other opinions though and i know many out there dont like the clutch. but i would recommend trying it and find out for yourself if it works for you. just be sure to get the new 3 shoe clutch and i would try the .7mm springs.
good luck.
Jammin SCRT10 Neu 1512 1y
Mentat
Brushless Mentat
Mentat's Avatar
06.17.2009, 04:02 PM
I just bought the tekno kit for my 8ight-t not shown up yet, i got it off amain, will it have the 2 shoe or 3 shoe clutch?
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
Ryu James
Ryu James's Avatar
06.17.2009, 04:06 PM
if you bought the kit for the 8t 2.0 it will have the 3 shoe setup and come with .8mm springs.
if you bought the kit for the 8t 1.0 that is on sale for $69 it will have the 2 shoe i am pretty sure.
call tekno and ask them to be sure.
877-857-2872
Matthew_Armeni
Matthew_Armeni's Avatar
06.17.2009, 04:14 PM
The kits from A-Main all have the the first version of the elektri-clutch. To upgrade to the 1 piece 2 shoe, it's $2.00 for shipping and handling sent to Tekno RC. To upgrade to the 3 shoe, it's $10.00. You'll also need a clutch bell, shoes, and springs if you go to the 3 shoe.
The 3 shoe is really the way to go in the 8th scale cars as Ryu said.
  Send a message via AIM to Matthew_Armeni
Ryu James
Ryu James's Avatar
06.17.2009, 04:20 PM
pay the few bucks for the upgrade to the 3 shoe. definitely worth it.
jhautz
jhautz's Avatar
06.17.2009, 04:41 PM
I tried the clutch and did not like it at all. Then I tried it again later with the 3 shoe version just to make sure and still didn’t like it. My basic problem with it is in the tighter technical sections of the track it feels very sloppy and imprecise to me. With the direct drive it makes the small throttle movements react like I expect them to. Even with the 3 shoe .7 springs the clutch still made the slow sections have what felt like a lag when I gave it gas. And then when it did go it went to much. I did like the way it smoothed out the bottom end hit coming out of corners and such, but for me the silpperential did just as good of a job once I got it tuned the way I liked it and in the slow sections still was very reactive and direct.
That’s my experience with it anyway. There are some that swear by it and some that totally hate it. I fall in the hate it category. But that’s just me.
If you have it, try it. It can’t hurt. If you don’t like it you can always go direct drive.
to make it...
or break it...
Silent...But Deadly
