View Poll Results: Do you want new switches
Yes 76 84.44%
No 14 15.56%
Voters: 90. You may not vote on this poll
nitrostarter
nitrostarter's Avatar
06.18.2009, 02:38 PM
WOW! So I was out running today. I just installed my M11 and spektrum reciever. I went to the track and I started making laps. Then all of a sudden, it started getting glitchy. It was acting as if the power was being shut on and off. I check it out. I had tried to rebind my Tx/Rx, same problems. All my parameters and ESC setting were fine. But it still glitched. Finnaly a thought came to mind, check the switch. I messed with it, and then cut it off and twisted the wires together, and sure enough, everything was fine after that. I'm sure glad it happened like that when I was practicing and not in a race... I would have been aggrivated. So I'll either solder on a new switch like I did my other MMM or just solder the wires together and not use a switch.
N. Rustler conversion
