the mini revo's esc is rated up to only 3s right? there's a youtube video http://www.youtube.com/watch?v=sA3CL00dPT4 saying it does 59mph on 4s!!?!?! I think they confused the fact that since they put in 2 x 2s lipos they thought they were running 4s (if they were using a parallel connector) but i believe its a series connector...IDK....and if you run 4s on the mini ESC won't it fry?
The owner of that video posts some over on the traxxas forums and said if you switch the ESC LVC off, it will run on 4S lipo.
I got mine and posted a Video before, Well today I did some work on it and discovered a bunch of interesting things. First off the Waterproofing of the VXL is basically just plastic dipped, Secondly a Medusa motor (36-50) could fit with very little modification, It will take a bit of dremeling to the Rear shock holder.Also here is some pictures of size comparisions.
