UE Supermaxx Addict!
06.20.2009, 08:19 PM
Welp, add a third Supermaxx to my build sheet, except this one is going to be nitro! I haven't had a nitro truck since about 2007, so I decided to build another one, and I might as well make it a Supermaxx!
I just bought a like-new UE Thunder chassis kit about an hour ago, and am going to slap a new LRP ZR.30 X Competition engine (with shaft-start) on it, plus all of the other UE Supermaxx parts for it...minus VBS.
Here is how I am going to outfit it:
[1] UE Thunder chassis, braces, center skid, Ti driveshafts, BB motor mounts, servo mounts, tank mounts, fuel tank, and antenna mount.
[2] RC Solutions 1.075mm spring-steel F&R skids (lighter than 3mm aluminum, lighter & stronger than 2mm titanium)
[3] UE Ultralite diff cases
[4] Ofna 6-spider diffs with UE outputs
[5] Hardcore Racing F&R bulkheads
[6] Great Assembly (GA) bulkhead braces
[7] UE Knucklehead shock towers
[8] Ofna Ravager rear shocks (identical to Supershocks, just a little longer)
[9] UE 6mm shock stand-offs
[10] UE Racer-X suspension
[11] UE Racer-X Setback lower rear arms (real ones)
[12] UE Racer-X Hi-Impact lower front arms (real ones)
[13] UE 6mm steel CVD axles
[14] Dace Mfg. 23mm hex-adapters
[15] Lunsford Racing titanium hinge-pins
[16] UE GenIV servo-saver steering system
[17] UE Progressive/Dual-Rate shock springs
[18] UE titanium front turnbuckles
[19] Traxxas 2.5 black transmission
[21] OTB input, 1st & 2nd gears
[22] UE Super6 FOC gears
[23] UE 4-shoe clutch system
[24] Strobe slipper system
[25] CNR dual-disc brake kit
[26] JConcepts wing on MBX-5T wing-stay
[27] Diemaker Dave wing-mount
[28] JConcepts Rulux ½" off-set Half-Ups
[29] Pro-Line LPR Bow-Ties
[30] Pro-Line Crowd Pleaser Revo 3.3 body
[31] Tony's Screws
[32] Acer Ceramic bearings kit
I think that's all...
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
06.20.2009, 09:40 PM
[31] Tony's Screws
I love it, I really do. But the reason I said that you need to create a build thread(s) a few days ago was because even if this thread is long in the tooth its still not your thread or the place. Oh and UE is making 8mm CVDs again!!
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
