06.27.2009, 07:05 PM
water isn't the damaging factor, its the resulting corrosion from leaving water sitting that damages componenets. I ran my mm throughout the winter, sprayed it well with wd40 to displace any water afterward, then air compressed it dry. Still runs like a champ. Remember, moisture is ok, corrosion isn't. Moisture will lead to corrosion. you can get them wet but dry them before damage starts.
