06.28.2009, 08:55 PM
A agree. If you gear any CC motor low enough (if even possible) for acceptable heat levels, the top speed is too slow. Either a MM/VXL motor or a MM/Medusa 36-50-xxxx motor works great.
emaxx 101
06.29.2009, 02:58 AM
Are the vxl stock bullet connectors compatible with the MM's directly out of the box or do I have to change them to 4mm?
fastbaja5b
fastbaja5b's Avatar
06.29.2009, 08:59 PM
You'd have to change them to 4mm
That said I went the VXL speedy on my Slash, the training mode is great for kids, and Castle says not to adjust down your EPA's to tone down the ESC which is a bit dumb. It also looks like it'd withstand the elements a lot better, When I see the MMM in my Savage Flux, I'm scared to run anywhere near a puddle, it just looks a bit fragile!
Say Less, Do More.
Tags
6900, mamba, maxx, slash, traxxas
