doo540
07.02.2009, 09:13 AM
I'm just hoping the lst2 diffs hold up. Still having problems breaking the pins that hold the output cups to the side gears in the diffs. I did check into using 8ight pins but they are the same part number, the 8ight does have a different part number for the spider gears themselve but the little pins are the same. I should mention this is only happening in the lst2 not the revos. I have a total of 3 e-revos that are running the lst2 diff conversion.
