Foxracin
07.03.2009, 11:00 PM
The SW have been known to have BEC heat problems when run on the full 3s voltage. Especially being in a sealed case and powering a high-torque servo. I'm sure a UBEC will fix that right up. Do you still have problems with the truck getting stuck on things?
I can pretty much jump over anything now.
Ill be picking up a CC BEC tomorrow. I made up a receiver pack out of some AA's and it worked perfect. So I know a external BEC will fix it.
Question? How many volts should I set the BEC at without frying the Spektrum receiver?
