Kcaz25
Kcaz25's Avatar
07.06.2009, 11:28 AM
Yea I've been seeing the wheely King stuff in your photobucket cool stuff!
SnoopMaxx
SnoopMaxx's Avatar
07.06.2009, 04:51 PM
It's more like 2 WK's I rebuild and modified it till there was only the axle housings left
Then I looked at all the stock parts laying around and decided that it would be cool to have an extra WK that the kid's can play with
Morten SnoopMaxx
Never to old to play
c",)
nice project
chrismechanic
nice project - 07.12.2009, 04:57 PM
snoop, i like what you are doing to that old e-maxx,
i to have a 3906 brushless project on the go, but i put mine in the project x for some reason, might have been under the influence at the time .
like the roll cage idea, i too made a welded steel roll cage around 4 years ago to sit under the hummer body (proline).
my son drove the truck at full speed into the rear axle on my transit and i must admit the cage was a write off but the internals were untouched.
thinking this time i may try a carbon fibre roll cage with c/f body panels, so its all one piece. hmmm ....
SnoopMaxx
SnoopMaxx's Avatar
07.12.2009, 05:27 PM
Thanks chrismechanic
I was out earlier today bashing my Maxx and it runs great with my 4K nimh batt's but I an waiting on a Novak 4s LVC from ModelsportUK so I can use my new 2s1p 3000mah LiPo's
Do you shop at ModelsportUK ?
or are there a good rc shop near you ?
Morten SnoopMaxx
c",)
chrismechanic
07.13.2009, 04:25 AM
hi snoop/all...i ran my truck sunday afternoon down the foresty bit on the end of the park, a five minute walk from home, went ok, popped a front shock and bent the drive shaft after a bad landing.
there is a model shop around 40 mins drive from home but i get parts from all over, my mm combo came from a main hobbies as was best price around.
i usually make any parts that can be fabricated at home.
are u still running the 775 titan in your maxx?
you will really smile whe u get lipo power in your maxx.
and smile even more when you go over to brushless.
lipos are 100% improvment over nmhi, i run 5s on my maxx and is blistering, also get a longer run time, i get around 45-50 mins.
whats an lvc? speed controller?
talk soon byee all...
SnoopMaxx
SnoopMaxx's Avatar
07.13.2009, 05:47 AM
Yes
It's a LiPo Cut-Off
Novak 4s Smart-Stop Li-Po Cut-Off
Protect Your Li-Po Battery Investment
Now users of all models and brands of ESCs can appreciate and enjoy the advantages of Lithium Polymer (Li-Po) battery packs without the fear of damaging the cells. The Smart-Stop Li-Po Cut-Off Module will monitor your Li-Po battery pack voltage and prevent the batteries from going below the critical safety voltage level. This is achieved using a combination of throttle interruption and a visual cue from the included ultra-bright blue LED. The Smart-Stop Modules are available for 2-cell (#5470), 3-cell (#5472), or 4-cell (#5471) Li-Po battery packs and can be used with any brand brushed or brushless speed control for car, boat, or air applications.
For racers and bashers alike, the Smart-Stop Module will prevent your vehicle from draining your Li-Po packs below their safety level. The Smart-Stop Module connects between the receiver and speed control, and is easily set up with a One-Touch Set-Up button to learn the ESC’s settings for accurate and complete control. The Smart-Stop Module will interrupt the ESC’s throttle operation with short periods of throttle blipping. This is a warning that the Li-Po battery voltage safety level is approaching, giving the user a chance to bring in the vehicle. In addition, the remotely-mounted, ultra-bright blue LED will begin to flash, giving a clear visual cue that it is time to stop the vehicle. If the vehicle is run beyond this warning period, the Smart-Stop Module will bring the motor to neutral while leaving full steering servo control.
Morten SnoopMaxx
c",)
