07.08.2009, 01:42 PM
Originally Posted by BL_RV0
Yes. It does void the warranty.
I figured. Thanx man!
Are there any 23mm rims that are offset that fit Maxx size tires wheels not 40 series. I'm asking because the ones I have now seen above don't fit the badlands very well. The badlands slump over to one side and stay that way (until the turn back the other way) espcially when turning at speed.
Thanx guys!
-Zack
Fat Kid Engineering
07.08.2009, 01:57 PM
Not sure if these are standard or 1/2" offset but the price is to cheap to pass up.
http://cgi.ebay.com/Pro-Line-23mm-Ve...lenotsupported
This seller has THE BEST Prices on wheels and tires on the Net ! I bought 5 sets a couple months ago and now there even cheaper ?!
07.08.2009, 02:07 PM
Damn bondo! 4 LPR premounts $32 plus shipping!!!
Fat Kid Engineering
07.08.2009, 02:28 PM
Hey I wouldn't Bullshit you guys ??
Thanks to that rotten prick Trevor I have 4 sets of tires I'll will not use for a couple years because I have so dam many sets to wear out first.
Bo-Hoo for me ;-)
I dont see them for $32 but i see 4 for $40...
07.08.2009, 02:30 PM
 Just realized 4x for $32 is tires only...
Fat Kid Engineering
07.08.2009, 02:33 PM
You need to check all the auctions prior to comitting because there may be different listings for the same item for a much different price.
07.08.2009, 02:47 PM
There is/are...
Fat Kid Engineering
07.08.2009, 02:58 PM
I couldn't resist looking around for another deal when I noticed this;
"Note: The seller of this item is away until July 13, 2009. You may purchase the item, but there may be a delay in processing your order."
07.08.2009, 03:04 PM
You know what? I think I have proline maxx size wheels! I bought them back in 06 or 07 and can't remember. Has anybody else noticed the slump?
Thanx for all the help!
07.08.2009, 03:08 PM
Thanx guys!
-Zack
What foams are you running?
07.08.2009, 03:22 PM
07.08.2009, 03:31 PM
Are they the molded ones ? if not thats probably the problem or you need stiffer molded foams. The older non molded foams disenergrate inside the tire after a while dont ever use them. I am not sure how good the molded foams that come with the tires now.
UE Supermaxx Addict!
07.08.2009, 06:36 PM
The Badlands do that "shift" from side to side on any MT/3.2" wheel, no matter what foam is being used. You can fix the problem by mounting the tires on the inner-most bead lip of the wheel, or by mounting them on LPR or Half-Ups wheels. If you need 23mm hexes, you will need to find a 3.7" to 4" 17mm wheel, like from Ofna.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
07.08.2009, 06:52 PM
River, I didn't know that about the foams thanks!
Bummer. Cool. Are you talking about adapters Chad? Won't the 17mm still be my weak point? What is best LRP or Half-Ups?
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
