Jabe
07.09.2009, 01:55 PM
How much can 150A version record in amps? Is there some limit, that it wont show/record more than say 200A?
J57ltr
07.09.2009, 02:04 PM
Don't know I have the value set to 200 in the min max tables, so I am not sure what the max is. I do know with a 600Kv motor and 4S 123 I have seen as high as 175 the only hotter motor I have is a 7700 that came with my MM. I normally don't run it like that right now I have a 3300 Kv motor and it pulls 95 amps with the same battery. I have tried the 7700 on 3S and got around 160 or so. I'll have to look at my logs, I log about everything even changes in gearing and tires.
Jeff
