07.13.2009, 04:53 PM
Yeah, someone posted that a few weeks back. Personally, if Deans are hotter than the wires around it, then they are inadequate. Heat would mean power loss on the connector, which means voltage drop, which means contact resistance.
No one has mentioned the age of Deans though. After hooking them up a number of times (especially on anything over 3s), the repeated spark can pit the contacts and introduce contact resistance. Doesn't mean that Deans are bad per se, just worn.
Byte
07.13.2009, 04:57 PM
I can't believe they are designed up to 30A. I'm running chinese deans in my Rustler VXL and they never got warm or something like that?
I will also run Deans in my brushless LST with a Pletti Bigmaxximum, Quark Airmaster 125B and Flightmax 5000mAh 30C 5S LiPo. Maybe I should remove those Deans and put some huge bullets on it?
