Update, LST diff mod-mod
brushlessboy16
brushlessboy16's Avatar
Update, LST diff mod-mod - 07.16.2009, 09:36 AM
Well in lieu of my failed center drive shaft couplers I had to come up with something stronger.. while rummaging through the spare parts and such i had- i found that the coupler to the standard LST center cvd looks very close to fitting with the tapered u-joint of the revo wheel drive shafts.... I had one of those "this just might work" moments...
The revo shafts had to be ground down slightly, easily done with a dremel- to fit inside the Lst coupler. once the fitting was done i squeezed the whole thing together in the vice so that it was a tight fit... then it was as easy as putting a pin through the entire assembly and setting it in CA-viola! Then you need to swap your modded u-joint over to the center axles and trim them about 3/16in to fit in the stock location. after about 2 hours of racing they are still holding up
