sikeston34m
sikeston34m's Avatar
07.18.2009, 10:45 PM
Originally Posted by auto2 View Post
ok how do you pull the termanal out of the connector?
I put the connector, wire side down, on the table edge. Then place the spade of a small screw driver against the end of the copper terminal. Then smack the end of the screw driver pretty hard.
Might sound a bit forceful, but it works.
auto2
07.18.2009, 11:15 PM
ok was wondering if there was a tab to stick something in/on/around. ill use your method.lol
sikeston34m
07.18.2009, 11:24 PM
Not that I know of. If you look closely at one of the terminals removed, it has one tiny tab that is turned up, and one tiny tab that is turned down.
It is these that provide the "snap" when you seat them. The only way that I know to get em out is to over power those.
