Thread Tools Rating: Thread Rating: 40 votes, 5.00 average. Display Modes
dethklok151
07.19.2009, 04:24 PM
battery tests would be awesome.is there anyway to use a fluke meter?not sure how many amps they can measure.what about using automotive battery testers for the amp draw?some good ones use carbon piles.our high school had one that was adjustable.just some thoughts,i do appreciate the fact that this all is being done on a slim budget.
also,since electrical minded folk might read this,how hard would it be to build a non adjustable output driver for a brushless motor?like to power a motor on a dyno,or a starter box?
J57ltr
07.19.2009, 05:07 PM
Flukes are only rated for 10A for most of them and 20 on a few models. You could use a shunt and measure higher loads, but then you have to convert milivolts to amps via a chart from the specs of the shunt
Using the Datalogger he is using will give recordable shots of exactly what's happening.
To build an non-adjustable drive for a brushless motor.
Simple version:
Use a servo tester an ESC, motor, power supply/battery. Connect them together and set the motor RPM you want. Remove the tester and measure (in Ohms) the pot for adjusting the "servo" between the middle terminal and one of the outer terminals, then the same for the middle and other terminal.
Write down those numbers and find resistors that match those 2 numbers. Remove the pot. There will be 3 holes where the leads of the pot were connected. Solder the 2 resistors into the 3 holes left by the pot and use the numbers written down earlier to determine which resistor goes on which side. You will have a lead from each resistor in the middle hole and the other lead goes into the outer hole. You will also need to have a Dual Pole Dual Toggle (DBDT) switch to be able to switch in 2 resistors of the same value half the resistance of the pot. (if the pot is a 5K you will need 2 2.5K resistors.) That way you have a neutral position and a place so the ESC can arm.
More complicated version should be handled in another thread:
Jeff
dethklok151
07.19.2009, 08:36 PM
for some reason, i thought my buddies fluke measured higher?oh well.
i was looking to replace the esc with a simple max rpm driver for a brushless motor.something simple and cheap.possible other uses might be for a starter box or a dyno,or better yet,to use a brushless motor to run a comm cutter!
HA! i digress though ,it should be in another thread...
