jsr
07.20.2009, 02:00 AM
The mount seems somewhat far from the spur. Are you sure you won't have any problems with the pinion reaching the spur? Even though some pinion gears are pretty long, I prefer to not have the pinion overhang (extend further than) the end of the motor shaft.
Since you have machining capability, why not machine a mount that replaces the rear center diff bulkhead like RCM mounts?
