skellyo
skellyo's Avatar
07.20.2009, 08:16 PM
Originally Posted by Finnster View Post
I'm quite impressed if you can run 5S on the beach w/ 40s and not fry anything. If I was designing the system from the ground up, I would still use higher voltage/lower kv motor, but whatever works. Its not worth trashing the system tho.
I was quite surprised myself with the temps of it. Of course when it just lights up the tires no matter the viscosity of the sand, it's not like the motor is having to pull gobs of current to get going.
