Kyosho
07.21.2009, 04:45 PM
ok, so if i get a 2000kv medusa geared 11/46 it will be. 46mph this is alttile fast for me. and to go with a lower diff ratio i would be spending close to $150, the air temps here are about 86*F, I live in Canada.
if i get the 1600kv motor it will be geared under 40mph, about 36mph with 11/46 gearing.
I dont drive Wide open all the time, i barely even get up to full throtle.
here it is with the medusa 1600
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 11
Total Voltage: 18.5
Motor KV: 1600
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 4.18 : 1
Total Ratio: 13.83217 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 29600 RPM
Vehicle Speed: 36.92 mph (59.31 km/h)
Effective KV Value: 1600
KT constant: 0.85 oz-in/A
