07.21.2009, 04:46 PM
Not an expert, but an "armchair professional".
07.21.2009, 05:55 PM
At least you admit to being lazy...
From my limited (HA) experience with various motors the neu seem to be the best out there. Generally the external looks are a bit questionable (black motor with crappy sticker) and I have noticed the variety of shaft materials that neu seems to use. I have a feeling you have a few different age stators in those motors, that would account for the differences in the shaft length and appearance. I once returned a neu with a fault stator and got a heli model stator back, the shaft must have been 1.5" long... Kinda funny, I just trimmed it down to the correct length and ground a flat spot on it.
I do understand your feeling s though, these motors are not cheap, and if I bought them neu I would be concerned about these same things. I guess function beats form, at least for me.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.21.2009, 07:07 PM
Yes, they would use a 30+ gauge wire and just wind them in a bundle... obvious reason being you can't wind 12awg or 10awg thick wires around a stator, at least not safely (damaging wire insulation).
This makes me ask the question, the people who have had problems with breaking motor wire leads, what Kv. winds were they? I can see the high Kv. winds having the problems... my 1512/3D has had zero issues with wire breakage and I have moved, readjusted, kinked the leads many times. They look to me like they would be about 12awg wire size equivalent.
