Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
florianz
07.24.2009, 12:34 PM
Absolutely correct, and it should be noted that HD recruited Porsche to design that engine FOR THEM... because oddly Porsche's design team is not stuck in 1910
yep... 1910 lol... progress, what's that?!?
porsche actually designed the last two engines for HD. but porsche have some troubles now... just got eaten by Volkswagen. soon the Porsches wil be just faster VW's... but that's a bit OT
Bad Karma
07.24.2009, 04:54 PM
TCS Cooling has RC watercooling kits the radiator listed is smaller but they do have a larger one available if you email them.
watercooling
transtalon
watercooling - 07.24.2009, 08:22 PM
I use the watercooling setup with my Hydra 240 and Neu 1527 1D and without the working water pump and a home made radiator similar to the picture up top it made my temps to drop from 170 degrees to 98 degrees on a summer day in IL. It works on cooling but not on ESC I beleive due to a rapid rise in heat when the ESC maxes out. It will cool down better than a fan but won't save the setup when the ESC goes up in flames. I was also using a 5volt diaphragm pump. The TCS pumps is a gravity feed and when your trucks rollover it needs to be primed in order for it to work. They are a piece of crap and not worth getting for 70.00. It does work just too much lines and a little weight.
Ryu James
Ryu James's Avatar
07.25.2009, 02:26 AM
wow guys. this is awesome stuff! i really like that TCS system and the little pc cooling unit. i think i am gonna search the web for some more of those pc cooling units and see what else is available.
transtalon: so are you saying the TCS is not a very good unit to use?
i really like the thermaltake kits but the radiator/fan is huge. 120mm fan and like 150mm radiator. check out some of these sets:
http://www.xoxide.com/watcoolkit.html
anyway, here are some recent pics. here is my front swaybar installed. now the rear is next.
Photobucket
Photobucket
here are some pics of the esc without the shrinkwrap. a fan would cool it decent i think on that large top alum. plate but the water cooling would just be soo cool. i will have to see what i can do. also, here is the rx/esc box i am planning on using. it fits everything perfect. i cut holes on each end for the wires to come out and then i am gonna use an outerwears material to cover the holes to keep the inside of the box semi-sealed off and safe from elements. (even include some hand porn.)
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
Jammin SCRT10 Neu 1512 1y
Ryu James
Ryu James's Avatar
07.25.2009, 02:39 AM
oh, while i am thinking of it does anyone know where to find some really small pulleys that can be mounted? the reason i ask is i may need some for the rear disc brakes. in order to run the brake cables smoothly to the brake servo i want to use a small pulley system. if its not feasible i could just use another servo closer to the rear of the vehicle and then use a y-harness to run both servos but i kinda want to run them all off one servo and i have already laid things out to where it could work if i have 1-2 pulleys. plus the servo i have is 425oz so i know that it is more than enough to pull all 4 brakes.
also, on the topic of water cooling, is there a water cooled motor sleeve that fits a finned Neu 2215? i was planning on using this fan ( http://www.coolerguys.com/ec60ledalum.html ) most likely as it fits the motor mount i am making perfect but if i use water for the esc it might be cool to use it for motor and esc.
Bad Karma
07.25.2009, 03:21 AM
Water cooling sleeve for NEU 2215
frozencpu.com has a large variety of PC water cooling parts
I'd use the jacket from OSE, large radiator from TCS and find a source for a high quality micro pump
Ryu James
Ryu James's Avatar
07.25.2009, 03:50 AM
i found a great site. frozencpu.com
check out this setup. tons of other options on the site.
tank/radiator combo
http://www.frozencpu.com/products/22...0c95s708#blank
pump:
http://www.frozencpu.com/products/60...tl=g30c107s153
edit: iwas typing when the last post was made. lol
watercooling
transtalon
watercooling - 07.25.2009, 10:21 AM
The links for the water reservoir looks tricked out. I think this is all you need and the pump that they are selling. The TCS pump is small and looks real good. But it works good as long as you don't roll over as it needs gravity to feed the pump. Also you need a high volume tank for it to work as the more water it has the more pressure gets deliver to the pump. I tried it but it's very unpredictable on pumping water. You'll just find out it's not working when you check the temps on the water. When it works the temps is about the ambient temp of the outside but when not it gets pretty hot. Watercooling really works on cooling the motor, it's pretty amazing to see that my motor went from 170 degrees to 98 degrees on a 90 degree weather.
