Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
07.25.2009, 05:30 AM
Ah, I usually don't sign in until I am going to check out.
Dang, $33.57, I may have to pick some up now..
go for the 30C...trust me
if they fit that is.
yeah i guess we do drive the same hehe.
that was my old nitro revo in that pic...i'll update that avvy when todays race photo's come through.
no ive never bent mine at all...it'd be interesting if we could swap revo's for a race...too bad there is a long distance between us :(
maby you could try the E-maxx plate? you'd have to spin the tranny 180 and in theroy it should be a bad thing in a race CoG wise....but it'd be interesting nonetheless
  Send a message via MSN to shaunjohnson
Jason
07.25.2009, 06:00 AM
mistercrash : the trick for diff block dont work with the stock e-revo diff I put the complete diff in a birthday balloon and then put in into the bulkhead and seem more tight then before should work just fine ? ... I cut 3 holes for the diff output ... and checked my diff pinion and ring gear look like brand new and the pinion dont needed to be shimmed and I dont got any move side by side with the diff case too.. but once I opened the diff the seal were the screw goes was broke so the diff leak but not by alot anyways im going to buy a seal and change the diff fluid one day.. and I forget the bearing was all fine ;)
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
07.25.2009, 10:30 AM
Quessé t'as fait là toé sti! Mette té diffs dans dé balounes Pourquoi pas du glaçage à gâteau dans l'diff tant qu'à y être C't'une joke là Bin si ça marche çé tant mieux.
Jason
07.25.2009, 10:35 AM
un plan de neye comme quon dit :)
j'ai défait le diff avant aussi pis lui pas eu besoin de rien toucher il est parfaitement tight cétait seulement lui d'en arriere qui avait un lousse
dave_mackinnon
07.25.2009, 02:33 PM
Bibliotheque!
Hahha.. Sorry, had to do that...
Hey mistercrash, where did you get the piano wire?
OK, so, who's up for placing an order for Lipo's? Maybe I'll start a new thread?
mistercrash
Guelph, Canada, eh!
07.25.2009, 08:17 PM
Originally Posted by dave_mackinnon View Post
Bibliotheque!
The wires I have were available at my LHS in the airplane section. But I found this also. I ordered a pack of ten 18'' rods to try out.
http://www.smallparts.com/Music-Wire...AF&pf_rd_t=301
mistercrash
Guelph, Canada, eh!
07.29.2009, 11:21 AM
Smallparts.com was fast in shipping the wires to me here in Ontario, Canada. I got them yesterday and what they sent me is better than what I was getting at the LHS. The wires are stiffer and are springier than what I was using before. So I went ahead and made a front sway bar right away and installed it.
Update on the battery doors. They are awsome, I am absolutely confident that the doors will not open up while running anymore.
