blueb8llz
07.26.2009, 02:27 PM
Arct1k- i already tried that.
speedybl- i use the same lipos on my emaxx with no probs. and i dont see any loose wiring.
im pretty sure metal man's guess is correct. i just havent gotten the chance to try another pinion. been real busy with job. will try in a few days.
J57ltr
07.26.2009, 04:41 PM
What is your gearing? 87/19?
Jeff
blueb8llz
07.28.2009, 12:50 AM
Jeff
no, try 86/25 hahah i told you i was geared super high.
J57ltr
07.28.2009, 01:58 PM
It will go faster if you gear it down (numerically higher). I have a friend that has the same combo I have and he will eat my lunch if I am geared too high. You are geared for about 75mph, it'll never get there. For sure this is the reason you are have weak brakes. If my friend is geared 87/15 and I am 87/20 I can't even come close to catching him. We both run A123's and the 7700 in a rustler. It won't even pull a wheelie with that gearing in my truck
(87/20) Even his top speed is faster than mine if I am geared too tall. And I usually have to have 100% for the braking force and it will slow the truck from top speed but as the truck slows the braking force drops.
Jeff
