tedo
Vermont, USA
tedo's Avatar
10.29.2009, 04:54 PM
I run 7/10/3. Works perfect with a concave throttle profile. Very little to no ballooning.
MBX6T: RX8 2000—sick!!!!
Campbell Buggy Rock Racer on 3S
4x4 Pede
1987 (Gen 1) Lunchbox
mihael
11.02.2009, 07:24 AM
which gearing you guys drive with which Motor and how much S on the lipos?
now i am driving the MMM2200 combo with 5s hyperion and 13 pinion
the pinion is to small and the 5s lipo is too much for the mmm 2200 motor
i go next week with 4s lipo and 15 or 16 pinion i think
diff oils in the middel and front under 15 000 makes the car to unstable. its no mather if nitro or if brsuhless. here in germany and europe much pro drivers drives heavier oils. 20 - 50 k in the front and middel
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.02.2009, 11:11 AM
5s on the 2200kv motor is extreme for sure. I use a 1700Kv or 1550kv motor on 5s.
I assume your tracks have super high bite/traction and a smooth surface - lower traction and rough surfaces generally require lighter diff oils for better stability - I wouldn't run heavier than 10k in the front and 20k in the center even on a smooth clay track.
mihael
11.02.2009, 11:18 AM
hi there yes i know, 5s is too much. my 4s lipos are on the way.
i am looking for a sammler kv motor to use with higher voltage in my mugen for runtime and good temps
Cain
11.06.2009, 05:38 PM
are those 6.5mm bullets on the motor connection?
BrushlessRacer
11.06.2009, 05:51 PM
Yes they are!
Just a test if they will hold on.
mihael
11.10.2009, 04:44 AM
hi there
now i drive my mugen with 50k 10k 30k in the diffs. ist the fastest set up i have ever tried without loosing steering
steering is much more then before.
no mather if on a loose or an a high grip track
mihael
jzemaxx
11.11.2009, 05:46 PM
Originally Posted by mihael View Post
hi there
mihael
Wow that is thick oil. I am trying 10 10 2 this weekend to see if I get the results I'm looking for.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
mihael
11.12.2009, 03:33 AM
our gemran master drives these oils on his mugen an other peopless too on their jammins. its no mather if the track is loose or with more grip.
jzemaxx
11.15.2009, 12:31 PM
Mike, does the kit for the 6T work on the 6 buggy as well? I just got the buggy.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
RC-Monster Mike
Site Owner
11.15.2009, 01:47 PM
We have a 6B kit listed as well - same basic kit, but a different battery tray fitted to the buggy. :)
jzemaxx
11.15.2009, 10:33 PM
Good. Be ordering tomm morning. Hopefully they are in stock
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
jzemaxx
11.16.2009, 02:18 PM
Just ordered....thanks!!!
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
mihael
11.18.2009, 05:33 AM
hi there
i am building my second mbx6t brsuhless truggy. so i will tkae rc monster parts again i like the balance and the leightwight compare to the tekno kit
so my quation
woul the rc monster battery tray from the mbx6 buggy fit to the mbx6t truggy? i do neo need a big batterie tray, 140mm are more then enough for my lipos.
mihael
RC-Monster Mike
Site Owner
11.18.2009, 11:25 AM
The buggy tray won't fit the truggy directly - the holes are slightly different. The truggy tray is significantly larger, but you can use the extra size to tune front/rear weight bias with a smaller pack. I line my trays with a thin foam(for traction and padding), which allows the battery to stay put during the run. Some use a small amount of velcro on the battery and tray to add positioning security. :)
