Smart diff will not fit in the Mugen so I doubt it will fit in a copy of a Mugen.
Actually you could make it fit but the outdrives are too short, Mugens are way longer. I also thought about swapping internals but the outdrive shafts are different sizes.
yeah the caster is just a downgraded copy of a mbx5 . so no smart diff? oh well.
Update: 48t spur is slightly too large to fit and interferz with the main chassis plate. However u can add four M3x3mm washers to raise centre diff mount to make it work.
