redshift
RC-Monster Square Tube
redshift's Avatar
07.31.2009, 12:02 AM
We have a 100 gallon unit where I work. In the winter months it will release very little, just a quick mist.
But in the summer, I get 4-6 ounces easily- you can see how quickly that would add up, and for example, with a 1 gallon tank you could be reducing the volume of the tank by a significant amount in a months time. Which means it's gonna run more often. And you'd definetely notice the vapor, not good for most airtools anymore than it is for the tank.
maxair45
maxair45's Avatar
07.31.2009, 12:11 PM
Yes I have a 80 gallon myself at my buisness and I keep it compressed when not in use, mind you I don't leave it on I turn it off and the tank is pretty well sealed up that it'll keep that pressure for a bit but I will not leave it on. I just when into the garage and saw the water drain valve thing and I opened it and the wierd thing is nothing at all came out.....not even a drop. I had it flat in its working position and I even tilted it tword the drain and still not a drop. possibly my environment I am working it in? Its pretty sunny and hot here slightly humid.....
I don't maintain my aircompressor or any of my equipment at my buisness(my job is to maintain a fleet of box trucks) so this is all a learning experiance to me. Another guy and I do all the work for the fleet and he is the brains of the operation so he does all that to keep all the tools in working order. I know truck not hardware.
Thanks for all the replys guys I really apreciate it
