Finnster
KillaHurtz
Finnster's Avatar
08.04.2009, 10:54 AM
I haven't read the whole thread, but I would be contented if you could adjust the auto-lipo LVC. Say I always want the cutoff to be 3.3V/cell, but use 4S and 5S batts. Nice to be able to easily switch between the two and retain conservative LVC settings.
Also, a tolerance adjustment to the LVC. You can drop below the lvc under certain situations. Would be nice to be able to enforce a higher or lower tolerance to the LVC alarms.
08.04.2009, 11:08 AM
Originally Posted by Finnster View Post
I haven't read the whole thread, but I would be contented if you could adjust the auto-lipo LVC. Say I always want the cutoff to be 3.3V/cell, but use 4S and 5S batts. Nice to be able to easily switch between the two and retain conservative LVC settings....
Um, that's already been done.
Foxracin
08.04.2009, 11:10 AM
You can do that now. They came out with a Firmware update back in May and it has that feature for all the Mamba's, and the Sidewinder and probably all the ESC's. It is v1.21.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
