08.09.2009, 03:20 PM
Timing: Low or Medium, probably medium as 4 pole motors like a bit of advance.
LVC: 3.2-3.3v per cell, auto lipo setting of 3.0v per cell is abit low.
Drag brake: dont like it myself, plus 4 pole motors have a natural drag brake effect anyway- good for racing and slinging the truck round corners.
Braking power: Low brake strength maybe, I run 40%. You can always play with the brake curve to reduce the instant feel to the brakes (add some exponential by dragging the line down at the 1/3 mark a little bit to make the line a curve).
You can do the same thing to the throttle curve, and it will reduce the tendancy for the truck to want to wheelie- kinda like having extra smooth accelerator control.
Higher punch control will reduce the tendancy to wheelie and produce lower temps, but it will also reduce the responsiveness of the throttle when you start getting to higher speeds.
