R00ST
08.11.2009, 12:35 PM
Each adapter is +1 inch PER side. I had him do this as 99% of buggy wheels out there are 0 offset (the hub mounts to the outside wheel face). If you were able to mount this on the stock hex it would narrow the truck by almost an inch. I figured this way it will actually widen the truck about 3/4 of an inch (maybe an inch) total which should help handling/stability.
david lamontagn
08.11.2009, 01:59 PM
The only thing i'am concern is about the longevity of the hub bearing
This setup will place alot of stress on it
GO-RIDE.com
08.11.2009, 02:27 PM
Yah the hub bearings are tiny on the crt.5 and get blown out easily by 1/10 truck wheels. At this time I'm holding out on any crt.5 mods till the new Ofna Blitz comes out that is supposed to be based on the Hyper .5
E-8ight - Tekin RX8 2000kv/4S
Foxracin
08.11.2009, 02:48 PM
Thats the 4wd corr truck aint it? Is it supped to be nitro or electric?
