08.11.2009, 02:08 PM
Since solar panels do not have much burst capability, I would opt for a lot more capacitance. Something like 3 (or more) of these: http://www.allelectronics.com/make-a...PERCAP-/1.html, or maybe even a couple of these: http://www.allelectronics.com/make-a...-CAP-/-/1.html
And any time you have that large of a capacitor, you're gonna have to give it time for the cells to charge those bad boys up before you run. Ideally, I would opt for a higher voltage setup (like 10v) with caps around that size, and then regulate them using a CCBEC or something. This will provide a more consistent supply which is less prone to voltage dips.
Maciolus
08.11.2009, 02:42 PM
These are realy nice caps Brian :) Thanks! I think I will use 5F of caps total.
I chose 5V to match outrunner diameter, voltage and potential velocity. If I have any problems with 5V I will resolder solar cells, add BEC and possibly ask my friend to rewind motor.
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
