Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
pasan
I <3 RC
pasan's Avatar
08.11.2009, 05:00 PM
Originally Posted by SpEEdyBL View Post
It's not current that's the problem but the voltage spikes that kill the esc. Even though a 48 amp battery can supply the needed current, it's voltage spikes will be a lot more violent, compared to those from an 80 amp rated battery. C rating mostly decided on being able to hold a voltage, which makes higher amp capable packs better. You'd be amazed at how high voltage spikes can get during braking, easily twice the pack nominal voltage with bad packs. Since the the MMM and MM both have 30 volt fets this was not an issue with the MM as 3s was the rated limit.
A little confused... I understand most of the intricacies behind brushless technology, but why would bad packs cause higher voltage spikes?
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
Pdelcast
Pdelcast's Avatar
08.11.2009, 05:05 PM
Because during braking the ESC has to dump power back into the battery. Packs with poor C ratings have high internal resistance, so to get the power back into the battery the voltage has to rise. The lower the internal resistance of the battery (higher C rating) the lower the voltage drop during accelleration, and the lower the voltage rise during braking.
Patrick del Castillo
President, Principle Engineer
littlegiant
10.11.2009, 02:12 AM
Will bigger capacitors help prevent damage then?
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
10.11.2009, 03:06 AM
caps are for huge amps for split seconds. acceleration can go on for more than a few seconds.
hence a good battery is needed.
