Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Jason
08.12.2009, 08:15 PM
im really sick of this buggy shit right now
im using a mamba max esc with bec disabled and a 1200uf 25v caps ans still overheat alot I cut a hole on the windshield of the body .. for the motor im using a medusa 36-60-2000v geared for onlu 29mph ...
motor : 167f
esc : 167f
batteries 90f
in about only 5min of runtime..
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 17
Total Voltage: 14.8
Motor KV: 2000
Tire Diameter (inches): 4.3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.94 : 1
Total Ratio: 12.64706 : 1
Tire Circumference (inches): 13.51 inches (343.12 mm)
Rollout: 1.07:1
Total Motor Speed: 29600 RPM
Vehicle Speed: 29.94 mph (48.09 km/h)
Effective KV Value: 2000
KT constant: 0.68 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
why people running this motor on big e-revo without any heat issue ? the buggy are not so heavy ... e-revo more weight then this ...
Andrew32
08.12.2009, 08:44 PM
i think somethings off in your buggy.
Is your drive line free? bearings good? motor good?
and you gotta remember the mamba max is a 1/10 scale ESC. Although you can make it work....it requires some close attention
