Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
BLBuggyBoy
08.12.2009, 11:57 PM
lmao of all people briang is recommending a fan lol
Jason
08.15.2009, 12:34 AM
are you running a fan on the heatsink? on the mm it is needed, just a small 25mm 12v fan is the best, hook it right up on the power leads, also drilling holes in the bottom case helps alot to
I dont run a fan on the mamba only a caps for the motor I tried with a heatsink also still same problems... the mamba max have already hole drilled on in the bottom case...
Jason
08.15.2009, 12:35 AM
Andrew32 : Yes the driveline are free all look fine gearmesh was ok too I tried many esc setting and same tried another esc also ...
Jason
08.15.2009, 12:38 AM
also the center diff was filled with 100k silicone fluid ... maybe the medusa 36-60 can are to small ? they are like a feigao L series...
08.15.2009, 12:47 AM
lol, you're right. Generally I would never recommend a fan, but then again, I wouldn't recommend a MM for a buggy either. But since he has the MM, the only way I can think of to drastically reduce heat would be to use a fan.
Jason
08.15.2009, 12:54 AM
ok for the esc but the motor ?
bad motor for my application I suppose ? :) or I know the windings of the motor was some damaged where the motor screws goes ...
