08.14.2009, 08:41 AM
4.6" is tiny, I'd think about something atleast 5.5" really- stick a piece of drainpipe over a normal MT rim, then stretch a rubber tube over that...
As for the motors, you cant hook an inner to a diff, they just dont develop enough power or torque to turn such a high gear ratio (only reduction is the diff)- even with one motor for each axle. Big outrunners like Turnigy or Holmes hobbies sell would be the ideal thing, but like I said, its a tricky thing to choose the perfect one as you can adjust the gearing, only by using smaller or larger wheels & using buggy or truggy diffs.
All said and done, there are MT foams available from a few places (Imexrc.com), or the HPI Phaltlines work well if you tape the insides and glue them to the rim well.
Using larger pinions has the same effect as using larger wheels after all, so it would be easier to find the right sized wheels that wont fly apart, rather than custom ordering massive pinions.
That, or find higher kv motors to use- the castleneu 2650s would still work fine if you have two of them in one truck....
Rivermaxx
08.14.2009, 11:24 AM
I know but so far thats the only really good option. I am going try to glue a bigger donut on a plastic wheel as I do have a set that are on aluminum wheels but they were not glued properly. The drain pipe idea has been done and it didnt work plus its way too heavy.
I could be wrong but it seems like they have plenty of torque to me especially with 2 15151y 2200 kv on 6s. I would get the lowest gear availible also and run really small tires (buggy 4") to lower the final drive even more. Dont forget the super high gear ratio and the required torque is being shared by 2 motors, 2 esc's and 2 6 s batteries and not one. I will acelerate slowly dont want any wheelies question is will it work. I punched the number in the calc and I got this: I put the amperage draw @ 100 amps not sure if that was right. Its 5 mph faster without putting anything in the amperage section. Remember this is only for one motor.
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Total Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 4
Tire Ballooning (inches): 0
Motor Current Draw: 100
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 1 : 1
Total Ratio: 4.3 : 1
Tire Circumference (inches): 12.57 inches (319.19 mm)
Rollout: 2.92:1
Total Motor Speed: 47520 RPM
Vehicle Speed: 131.51 mph (211.25 km/h)
Effective KV Value: 2140.54
KT constant: 0.61 oz-in/A
Motor Torque: 0.32 ft-lbs
Final Torque: 1.38 ft-lbs
Final Power: 2220 watts (3 HP)
My g-maxx is going to pretty light also, so if one 2200 kv in a erevo can go 89 mph shouldnt double the hp double the torque double the volts (kind of) go over 100mph.
All said and done, there are MT foams available from a few places (Imexrc.com), or the HPI Phaltlines work well if you tape the insides and glue them to the rim well..
I have read the imex dont work at speed the foam gets thrown of the wheel. Hpi phatline is a viable option not sure if just tape will work but OverrevO the guy with the 91.2 mph erevo glued 40# test carbon fiber fishing line on the groove in the tires. Heres a pic:
Here some pics of the 5.100 tires I have. Whoever mounted them used the wrong glue so I am going to dismount them and try to glue them on plastic wheels with good ca glue.The biggest issue being the foam is to thick and heavy so when I am going 75+ will the centrifical force throw the donut off the wheels.
Donut that came off the wheel on the first run.
Next to a proline mtr about .500" difference in diameter.
Using larger pinions has the same effect as using larger wheels after all, so it would be easier to find the right sized wheels that wont fly apart, rather than custom ordering massive pinions..
I agree with you there I could do a revo conversion slipper setup like yours and run a 36 tooth spur with a 25 tooth pinion (same gearing as the 91.2mph erevo). Heres what I get on the calc with 5.5 tires which are phaltline size.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 25
Total Voltage: 22.2
Motor KV: 2200
Tire Diameter (inches): 5.5
Spur/Pinion Ratio: 1.44 : 1
Total Ratio: 8.20308 : 1
Tire Circumference (inches): 17.28 inches (438.88 mm)
Rollout: 2.11:1
Vehicle Speed: 94.79 mph (152.26 km/h)
Final Torque: 2.63 ft-lbs
It says ~88mph with the 5.100" tires I allready have.
It says ~77.5 mph with the 4.5" tires.
It says ~69 mph with the 4" buggy tires.
Thats smaller spur looks like the route I am going
Spinning a 2650kv on 6s is right on the borderline of 60000 rpm max not sure if I want to push it but it is a possibility.I think the 25 tooth pinion 36 tooth revo spur conversion is moving in the right direction though. Thanks neil for all your input you have got my brain turning now. lol
This is the chassis I am going to use as I am going to swap it with a g4 chassis and use the g2 for the speed trials.
Its ashame I just finished this truck.
