Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
KaztheMinotaur
KaztheMinotaur's Avatar
08.17.2009, 03:36 PM
I bent a hook on the end of a straightened coat hanger and hung the gear on it. My mechanic heated it up with the torch to cherry and I dropped it into the oil.
Ryu James
Ryu James's Avatar
08.17.2009, 04:12 PM
just used motor oil? or new? 10w30? lol.
Jammin SCRT10 Neu 1512 1y
KaztheMinotaur
08.17.2009, 04:41 PM
It was a misture of new Wal-Mart brand 10-30 and Valvoline 10-30. Thats what I had laying around.
KaztheMinotaur
08.18.2009, 12:09 PM
I had to do some dremel sanding to get the hub to fit into the milled out area after the hardening? Wonder if the gear would have changed size slightly ? Or maybe it was a buildup of oil bakes on gunk ?
Ryu James
Ryu James's Avatar
08.18.2009, 01:59 PM
i bet it was due to buildup of the hardened coating.
my machinist made a mistake on my motor mount plates so he is making new ones today. i hope to get my motor mounted up tonight.
hey kaz,
after you heated the gear and dropped in oil did you then heat again and drop in water? didnt someone here on the forum say to do it that way? or is that necessary?
KaztheMinotaur
08.18.2009, 04:25 PM
The machine shop I went to said to use oil only.
