sharkattack99
08.19.2009, 10:59 PM
well i wanted it to be 4wd drive cause i figured better control and partly the road and im a 4x4 nut lol, the road was made with glue and gravel there is no loose graval now its a pretty decent but nothin like a highway or freeway. so a decent 8th buggy and highest kv i can find? so basically it will be the bearing i use will be what gets me to my speed then?
dude sorry hear about ur ankle, i got in the way of my savage when it was still nitro cause it shifted ofv a hill scraped the hell out of my leg.
brushlessboy16
brushlessboy16's Avatar
08.19.2009, 11:12 PM
high kv equals bad
Low kv and more voltage.
and you should really look for a smoother test location. blacktop is best.
sharkattack99
08.20.2009, 01:08 AM
high kv equals bad
so this would be better? http://www.amainhobbies.com/product_...r-Combo-1350kV
then gear higher as i want to go faster low spur and high pinion right for gearing up, still not really understanding this gear up or down stuff. what do you up or down?
why do you glue fishing line around the ouside of the tire, the part of the tire that touches the road or were the wheel and tire meet?
Ryu James
Ryu James's Avatar
08.20.2009, 03:23 AM
how comfortable are you doing custom work? if you want off road and 100mph here is what i would do.
losi 8t 2.0 Tekno brushless chassis and conversion kit with 44mm mount
losi 8b 2.0 buggy a-arms front and rear. put the buggy a-arms and CVDs on the truggy chassis so you have a very long but narrow and low off road car. (RCM member has done this)
also, you will need to run those GP rally 1/8 tires cuz buggy tires will just come apart. my losi brushless 8 2.0 clocked at 56mph and 3 sets of tires were destroyed just to hit that. both AKA and proline sets. 100mph is a lot tougher than you think just a heads up.
anyway, in the motor dept. i would run a Neu 1521 1.5d F on 6s lipo with 35c 5000mah rating. the MMM should be fine for the esc.
then for gearing take the 2 speed center diff from the inferno GT and mount the inferno gt center diff mount to your losi chassis. now you have a 2 spd. get the 2spd pinion from RCM with the tallest gearing possible and you should be good to go. even doing all this you will be very hard pressed to hit 100mph. youll have to make adjustments to the body or a custom body to avoid flight. also many other unforeseen challenges will occur i promise you.
i would probably even use the inferno gt shocks and mount them on the losi for super low cg. so all in all it wont really be off-road.
really what you are asking for is impossible. a 100mph speed runner on one hand and a daily backyard off road basher on the other?? aint gonna happen. even at the World RC Speed Record races where people dedicated to RC speed come from all over the world there are dozens that show up but you can count on one hand how many break 100mph. and that is in perfect conditions and a prefectly smooth drag strip.
but if i was going for 100mph what i mentioned above is how i would do it if i wanted to do it cheap and just try it. good luck!!
Jammin SCRT10 Neu 1512 1y
