Unsullied_Spy
Unsullied_Spy's Avatar
08.20.2009, 02:33 PM
From what I've seen, the 80s like to run hot. As long as it's warmer than 60 out mine always gets up 140-160 before the end of the run and I have to stop to let it cool. They are powerhouses though, my Muggy pulls standing backflips with 30k in the CD and 40 series wheels/tires. You may want to look into a heatsink clamp for it though, my rear endbell popped off yesterday, there's not much of anything holding them in.
Finnster
KillaHurtz
Finnster's Avatar
08.20.2009, 02:41 PM
Yeah, I'm waiting for them to be in stock. Ideally Mike will get the Medusa version made so I can avoid having to get a front plate as well. I'm taking it easy for now. Thanks for letting me know on the heat. I was driving in 95F heat, so it was horrible. As long as it stays under 160F for all but the worst abuse I will be happy.
I want to get another roll bar to go over the back end as well. I don't want a bad landing on the roof w/ all those unprotected $$$ electronics.
Finnster
KillaHurtz
Finnster's Avatar
08.25.2009, 07:30 PM
So I've been running it a bit, and decided that I was a bit overgeared. Nothing got too hot, but it seemed a bit too sluggish on the bottom, and a bit fast on the top. No wheelies either. Did some wierd thing as it got hot too. Don't want to blow this controller up, so I better off backing down. I went down to a 15T from 18T, but I'd prefer a 16T if i had one.
Power dropped a bit, but it was more snappy low end and controllable on top and plenty fast. Wheelies too. Temps came down a bit.
The esc still said 150A peak, but volts were right on. Temp was way off tho.
