Thread Tools Rating: Thread Rating: 7 votes, 4.43 average. Display Modes
danhfvcsd
08.20.2009, 06:09 PM
Instead of using the FLM LST shock mounts, you can just use the standard Losi shock mounts - i know for a fact they work fine on both my savage flux and savage 21.
I have the FLM mounts on the FLM chassis, but, with all those mounting holes, i can only manage to mount them in one position (can you believe that?!?!) without the shock rubbing on the chassis (i have the chassis spacers installed)
I drilled out the stock pistons slightly larger and used 35wt oil, and they're great =)
Whatever you do, DO NOT get the integy piggy backs... they are great except for the shafts and lower mounts - if only they used the same shaft size as losi did, then they would be awesome with the TiNi shafts and standard losi lower mounts (lower mounts = where the shock attaches to the lower arm, i forget the name)
