DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.21.2009, 12:39 PM
I've gotten my losi 8ight to the mid 90's running a 1515 1.5D on 6S 30C lipos geared 43/25. I don't think a 2 speed is necessarily the way to go unless the 2nd gear is higher than any you can find in a single speed like most 1/8 buggies have. Mike's rcm mount is absolutely necessary for the 8ight as it allows for the biggest gearing.
I do use the losi rally tires, but sadly, they have been discontinued.
http://www.horizonhobby.com/Products...dID=LOSA17768B
there has been some rumor of them coming back, but nobody seems to know when or if it's true.
the part of Virginia i live in has alot of bad streets that never get cleaned from the winter's salt dumps. so running foams is not an option for me as all they do is slide. So now i have to go back to running buggy tires from ebay.
However, the good news is you can make virtually any pre-mount tire run the 100mph mark with the fishing line test method without them blowing.
OverRevo's fishing line technique is genius, but I do mine a little bit differently, but it works just the same. i don't cut the groove in the rubber. i just wrap the line around 3 times, in 3 different sections....each edge and the middle. i then tie it off and then put a drop of ca glue over the knot to keep it from un-tieing. incredible. it cuts down the ballooning by 80% imo. Technically i think it's even faster than the rally tires because the line does allow for a tiny bit of ballooning thus giving it a higher "theroritical" gearing due to the tire size increase.
i have tested every tire that the ebay store carries (i think) and my favorite for the street was the mohawks. i'm doing the same method with 4 rows of the braided line and they are rock solid.
i chose the mohawks for 2 reasons....they grip on everything and the tread pattern is very tall. (almost like the gladiators) This method will work as long as their is tread on the tire. after that, you'll have to cut grooves like OverRevo did.
I also glue beads of IC-2000 around the edges of the rim to meet the tire on both sides just to backup the factory gluing job.
this method has worked on every tire i own so far. i've tried it on the following:
1. crimefighters
2. mohawks
3. talons
4. HPI phaltliners
5. badlands
6. bowties
For my initial 90+mph test run I used the supra sales "crimefighter" style tires and used this for the re-enforcement...example:
it's Stren Sonic Braid fishing line. 65lb. I got it at Dick's sporting good store. it works AWSOME.
here's what it looks like done:
my next test to break the 100mph mark is to get a 1521 1D (2900KV) and run it on 5S with a custom made 30T pinion
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
