Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
KaztheMinotaur
KaztheMinotaur's Avatar
08.24.2009, 02:53 PM
Well here is my Jim Williams mount. It is a little different that I thought. What I will probably do is sandwich each horizontal slot between 2
L- brackets. Then the L-brackets will be bolted to the chassis. This way I can move the mount for pinion changes with out cutting a big hole in the chassis.
I though the mount mounting screw would thread up into the bottom of the plate...by bottom I mean the surface that sits on the chassis.
I was probably going to use some stick on velcro pieces and velcro cinch straps.
Ryu James
Ryu James's Avatar
08.24.2009, 03:43 PM
it looks alot nicer than in the pics on the website. i thought what you did though. that holes were in the bottom and you just bolted it up to the chassis. but the L plates is a good idea.
Jammin SCRT10 Neu 1512 1y
KaztheMinotaur
08.24.2009, 05:10 PM
I just made (8) L-brackets out of some 3/16 aluminum flat stock I had laying around.
