Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
GT35R
08.26.2009, 10:00 AM
Zetor, mine burned up on its second run too.
I only changed timing to 7.5deg, after reading about the dangers of low punch setting.
Your lucky nothing else burned up when it went off, mine did quite a bit of damage.
It sucks because you soften settings to be careful and nice to your car, not realizing
it could turn it into a time-bomb. I will definately not touch anything other than cutoff
voltage when I get mine back, and will run it without the new body on till I am sure
it will be OK.
Either way, it is NOT acceptable for someone to have to troll forums to pick
up vital info to prevent failure and damage when you are just following the
manufacturers instructions.
