Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
08.26.2009, 10:36 PM
I made mention of it in another thread, but there is a possibility that I will be making top-plates and chassis for the G2 & G3, maybe even the G2R & G3R if I can get some original pieces for measurements, out of thicker/stronger materials.
The reason is because a lot of people have been bending the very thin 2mm top-plates, and some have bent the 2.1mm chassis as well. Because of this, I thought it would be a good idea to make some replacement top-plates out of 3mm 6061-T6 aluminum, 2.5mm 7075-T6 aluminum, 2mm 6AL-4V titanium, and 3mm carbon-fiber (3k weave). I also think I am going to make replacement X-braces as well, out of both 6061-T6 and 7075-T6 aluminum.
I am, of course, going to contact Gorillamaxx and let them know that I do not intend to copy their designs, but just make stronger versions out of stronger materials. I am also going to ask them about maybe getting the rights to make the parts that they no longer produce. How cool would it be to get their original CAD/CAM files?
Anyway, I am buying a new CNC machine so that I will be able to produce the highest quality parts possible, and I actually have access to the highest quality materials for free. They will be scraps left over from previous milling projects, but they will be large enough to make all of the parts I want to make. Below is the CNC machine I am getting.
CNC Masters CNC Baron, with optional 4th Axis:
-Chad
PM ME IF YOU HAVE THE BELOW:
MiRatlhed
RCMTC-MI
MiRatlhed's Avatar
08.26.2009, 10:59 PM
HaHa that is funny Chad, I was reading the post and I am thinking to myself man I wonder if he can make me a set of VBS Bumpers. I got a set from a dude and they are pretty shabby. I would like a new set out of 7075 or Ti. Then I read your signature and you are looking for a set.
That is a really nice machine you are getting. I hope you do get the rights, might just have to be a good customer of yours. I have two G3R's.
PM me if you think you might be able to make a set of bumpers.
I have a question for you. I had my heat exchanger switched out in my Heat pump for my swimming pool and the whole exchanger tubing was made from Titanium. So I have a roll of Titanium tubing that weighs close to 6-7 lbs at the least. Could this be melted down and made into something else?? Or does it kind of lose it's integrity once it is made into something in particular.
Thanks man
