Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
KaztheMinotaur
KaztheMinotaur's Avatar
08.27.2009, 02:48 PM
Well there is almost no throw with out grinding.
The steering throw is really bad with the big MT tires but not bad with Baja rears all around.
Integy tech support sent me a bunch of photos of the brakes installed on a Baja inresponse to my request for instructions. They are also going to give me a "special discount code" for my next order.
Ryu James
Ryu James's Avatar
08.27.2009, 04:42 PM
can you forward those photos to me?
are you saying there is no throw with just the stock setup or are you saying there is no throw once you put the brakes on?
Jammin SCRT10 Neu 1512 1y
KaztheMinotaur
08.27.2009, 06:05 PM
No throw when you put the brakes on. I got it fixed though with a little grinding.
I got the brakes all hooked up. The piece that brings the 2 cables together needs to be shimmed up to the level of the servo horn. I am going to add some flat stock to my new front plate when I make it. I hope to work on that tomorrow morning.
I forwarded those pics.
Ryu James
Ryu James's Avatar
08.27.2009, 06:38 PM
ok isee what you mean, youre right. not that i am home i can look at it and yeah the caliper hits the spindle carrier. i never noticed before cuz for one i havent spent any time on that yet really but also i dont have my steering turnbuckles hooked up so the front wheels just kinda flop around right now. glad that just a little grinding fixes it though.
i bought some of this nylon tubing. got this idea from that baja in RCCA i was telling you about. i wish i had some pics to show you but it looks really clean cuz the tubing is so small and its much more flexible so it is easier to feed it to where you want it to go i think. its cheap so i ordered some to see if i will like it or not for the tubing around the brake cables.
http://www.usplastic.com/catalog/cat...ame=119&Page=1
KaztheMinotaur
08.27.2009, 08:09 PM
You got that to encase the cable in instead of the tubing that came with the brakes?
I discovered that you don't need to make a new front plate...just flip the stock one over.
The shorter brake rod will have to be cut down a lot. I'm also going to flip the brake servo around to the output shaft wil be to the rear.
Ryu James
Ryu James's Avatar
08.27.2009, 11:05 PM
yeah, the new tubing is to encase the cables....at least to try and see how it works. i may stick with the tubing they came with.
are you saying flip the front plate over so that to move the chassis brace over a bit or for some other reason?
KaztheMinotaur
08.28.2009, 06:55 AM
Yeah, flip it over so the brace is out of the way of the motor mount.
