08.28.2009, 09:02 PM
Nice...I tore apart my mbx-5T yesterday and in the process of changing fluids as I continue my BL conversion. Just waiting for the motor mounts to come back in stock so I can place an order w/Mike for that and a motor & batt. tray
08.28.2009, 09:16 PM
Cool bro, looking forward to more progress...
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
08.29.2009, 02:31 AM
Thanks guys and thanks Mike, I might alter my setup, not sure yet. This places the motor extremely close to the center diff so I may keep it this way.
Got more goodies today. My charger and other batts should be here Monday/Tuesday and that should be it. I was hoping to at least have my charger here by today or tomorrow so I could possibly run it but my time is pretty crunched this weekend anyway.
Hyperion goodies
O rings galore, picked this up for $7 a while back
Kyosho spur vs Mugen spur. As you can kinda see, the inner hole is just too big. I need to sleeve it in order for it to work. Other than that, it seems to bolt up. I just need to find some thin tube to go over my drive cup shaft. Sounds a lot like contraceptive, huh?
Center diff reassembled with 10K fluid.
Front steering plate, stock config
Same plate, flipped for motor clearance
Placement of brace in new spot. It's a little offset, but it should be fine. Still playing with this, might have to make the braces go to the center diff instead. I don't like that design, but this may not serve it's purpose in this location. More on this later.
:D
gtxracer
gtxracer's Avatar
08.29.2009, 02:32 AM
You can kind of see the outline for the cut of the flipped spur gear location here:
Progression...
Mounted
:D
gtxracer
gtxracer's Avatar
08.29.2009, 02:33 AM
Motor and battery placement. I'll have to trim the battery tray a little. It's a tight fit on this side, but the payoff will be balance!
And the man behind the build. My buddy Dan took this while I was working tonight
:D
