J57ltr
08.29.2009, 01:36 PM
Not even for the big scale stuff the more transfers you have the more losses you have a well designed heatsink system will outperform even a watercooled system if you have real long run times (an hour), thermoelectrics add complexity and you are going to loose 30% right off the bat. Run off of a power supply they are great, but batteries even Li-po you are going to run out of power in a hurry. When I charged my 4S1P pack last night I put about 1.4Ah back into it and only ran it for about 25 minutes give or take 5. I was going to graph it but I didn't bother I may later today with the temps and everything so you can see how they can perform.
JEff
